-   -   EVX+Titans Stutter? (https://www.rc-monster.com/forum/showthread.php?t=659)
Nick 06.02.2005 03:27 PM
EVX+Titans Stutter?
I noticed recently my G-maxx stutters. It sort of loses power then quickly gets it back again, sometimes stops completely, I have to let go of the throttle and accelerate again.
I think it is something to do with my EVX? Or Titans? They seem to be hot after a run, is this the cause?
Please help,
Thanks.
C.H.U.D. 06.02.2005 05:22 PM
Re: EVX+Titans Stutter?
Please help,
Thanks.
Are your batteries laying on the ground next to it? ;)
When it stops running do you have to let it sit for a minute before it starts running again or just let off the throttle for a quick second and proceed to gas it again?
You may wanna check the temps (how long can you touch the motors, batteries, and/or speed control?). And you may wanna look for loose connections in the wiring. Consider the solder connections in your battery packs as a potential problem, in light of your recent issues w/ the batteries staying in the chassis.
maxxdude1234 06.02.2005 05:28 PM
are you sure you've got capacitors installed on the titans. I once tried to run titans without them, and it was uncontrollable - very similar to what your describing
Nick 06.02.2005 05:37 PM
CHUD is right, I have to let go of throttle, wait for abit, then it goes again for a while.
Capacitors are on, and soldering done well.
Nick 06.06.2005 02:43 AM
I revesed the motor wires (red to black instead of red to red) and it works fine now. :)
Any reason why this would of caused it?
maxxdude1234 06.06.2005 05:37 AM
modern technology.....sounds a bit like my computer!! :rolleyes:
