lipo
what does the s and p ind the lipo 2s2p or2s4p mean:032:
s is the # of series cells, p is the # of parallel cells. You can play with the various settings on this page (the top section) for a visual aid.
thanks what is the difference between having more parrel cells compared to having more series cellls
paralell is wired in tagther for runtime , and 2s is 2 wired in for voltage
i THINK |
Paralel adds the capacity of the batteries, series adds the voltage.
Two 3.7v 4000mah cells wired in paralel would be a 3.7v 8000mah battery. Two 3.7v 4000mah cells wired in series would be a 7.4v 4000mah battery. Using cells in paralel divides the current draw between them, making it easier on the cells than if they had to put out the full amount of current by themselves. Some batteries are wired in paralel and in series. |
Read the sticky in the brushless section 'brushless in general'
| All times are GMT -4. The time now is 12:21 AM. |
