-   -   bk help (https://www.rc-monster.com/forum/showthread.php?t=6629)
rampingray 05.02.2007 07:30 PM
bk help
i got a emaxx second hand with a bk warrior esc and i tried to program it but i plug it in like the sticky says but i don't hear a beep then one time it beeped but the was no second beep. what up?
MetalMan 05.02.2007 07:40 PM
Have you tried reversing the throttle channel? Have you tried changing the endpoints and throttle trim?
rampingray 05.02.2007 07:43 PM
well does that have anything to do with the motor not beeping?
i can't adjust end point but i can reverse it
MetalMan 05.02.2007 09:12 PM
If the Warrior isn't getting the right signal (could happen if the channel is reversed) then it won't program.
Serum 05.03.2007 02:25 AM
Yep, i had the same 'problem' with one of my 9920's.
The set the throttle offset to 0 percent, and try it with the reversed throttle channel.
