-   -   Hybrid 1/8 revo diffs help (https://www.rc-monster.com/forum/showthread.php?t=6667)
luvsrc 05.05.2007 04:53 PM
I'm planning to install the hybrid diffs but some how it doesnot fit right in the bulkheads,it is a bit bigger from the regular ones any suggestions or tip to install it? thanks a bunch for all your help
Serum 05.05.2007 05:39 PM
What is the problem? have you got issues with the output pins? the entire diff should fit without too much effort.
Did you ever installed stock diffs in the revo?
Can you explain what doesn't fit?
luvsrc 05.05.2007 06:01 PM
It has the stock diffs and i want to the original diffs into the1/8 hybrid diffs into the but somehow it is not fitting right seems like it is slight bigger than the original stock diffs installed in my Revo.The out put pins that connect to the shaft is too high it touches the upper part of the bulkhead
Serum 05.05.2007 06:08 PM
Okay, if i understand this right, you are using stock diffs in the 1/8th housings?
This wouldn't work, because they use a different size of bearings, and the bearings for the 1/8th conversion are flanged to keep the diff in place. (centered)
jhautz 05.05.2007 07:42 PM
I had this issue when I installed mine too. I got a set from the very first batch and when I installed them the output pins were slighty to long. I had to split the bulks to get them in. I told Mike about this and he said that he had made the adjustment for all future production. Did you get some of the very first release? Any newer ones out there should not have this problem.
I'm planning on changing out the outdrive pins on mine when the first time I tear them down to replace fluids and stuff.
Even if you have to split the bulks its not that hard to do. Just a few screws and the bulks split and they drop right in.
luvsrc 05.05.2007 11:34 PM
yes i got the first batch
Serum 05.06.2007 02:56 AM
In that case; contact Mike for the shorter output pins.
