Neu motors - D vs. Y winds
Hey guys,
I have a 1515 2.5D coming in, but now that I think about it, it may be too much. I'm running an 8XL on 5S and it is stupid powerful. Full throttle is uncontrollable. I am now thinking that I should have gotten the 1.5Y which has a slightly lower kv rating. I've also heard that the Y wind motors are more efficient. Is this true and if so, does it make a difference? Is anyone one else running a 1.5Y? How do you like it? I'm going to be running mine in my Muggy conversion. |
no, not neccesarely more efficient. They are wound in a different way. not meaning that both a Wye and a delta of the same KV value could be close in effiency.
I have got a 2200kv neu laying here, waiting for a 5S project. They seem to be able to handle it quite well. the 1515 comes in a 4100kv too.. :p |
When I said that the 2.5D on 5S might be too much, I wasn't worried about the motor being able to handle it. I was worried about my truck being able to handle it.
The 2200kv motor on 5S is going to be insane. |
Efficiency wise they are pretty close to each other, Y will have copper losses while D will have core losses.
In the past (and sometimes in present) D windings were more hard on ESC to identify rotor position, nowdays electronics are much better... |
So, if I'm understanding this correctly, there really is no advantage of getting one over another. I'll keep the one with the kv rating that I want.
I did have one thought though. Is it possible that while the Mamba Max comtroller might have problems running a Nue motor with a D wind, it might have less trouble running a Nue motor with a Y wind. Which is the lesser of the evils; copper losses or core losses? |
copper vs core -> hard to say from motor side copper from generator core |
| All times are GMT -4. The time now is 06:52 AM. |
