-   -   ESC Motor leads and BEC (https://www.rc-monster.com/forum/showthread.php?t=6678)
Electric Dave 05.06.2007 04:03 PM
I'm about to try using my Mamba Max to run my E-Truggy. I'm using a 4s LiPo setup, anyway what male connector should I put on my motor to mate up with the ESC female? I've got some Team Orion 4MM but they seem a little too big...
and
How do you disable the BEC, I've got an external UBEC I want to use. I've heard you can just clip the red wire and that will do it but I wonder if you guys can confirm that. Someone also told me I don't have to clip it, that I can somehow back it out but I can't see how to do that, any info would be appreciated.
Thanks!
DM
BrianG 05.06.2007 04:19 PM
Most people either use 4mm plugs or hard-wire the motor wires directly to the ESC wires. The plugs makes swapping motors and/or ESCs a little easier, but hard-wiring provides a better connection.
Yup, just remove the red wire from the throttle plug. Clipping the wire works, but a better way is to pull the actual connector out of the plug. Just use the tip of an Xacto blade to slightly bend back the plastic tab holding the connector in and pull it out. Then, I fold the wire back against the throttle cable and heatshrink it.
Electric Dave 05.06.2007 10:03 PM
OMG - you would not believe how long I've been in this hobby and NEVER knew how those things were held together! That was SO easy! Red wire pulled back...Thank you so much.
DM
BrianG 05.06.2007 10:04 PM
lol, cool! I guess it's true that you learn something new every day! :)
Electric Dave 05.06.2007 10:14 PM
Well, since I'm in a learning mood...anything I should watch out for pushing this thing to 4s? I know the manual says 3s is the limit but it seems so many guys are about to make it purr on 4s I figured I'd give it a try...my 18.97 is so flakey...
DM
AAngel 05.06.2007 10:33 PM
Which truggy are you going to run this in? Generally speaking, just keep an eye on the temps.
BrianG 05.06.2007 10:34 PM
Just watch for temps. If things get too hot, you might want to adjust gearing.
If you haven't already done so, these two threads may answer a few questions:
Temperature FAQ
General brushless information
Electric Dave 05.07.2007 10:38 AM
Thank you, those are excellent threads...I've read all the post info and printed the PDF...
DM
