warrior marine esc
On a 9920 marine esc, do you still need to pull the neg. wire even with the bec jumper pulled when running a 4c lipo? Sounds like a lot of guys are having problems with these things burning up. :(
No, the warriors should not have the red wire removed. (according to the manual)
Thanks, thats what i thought too. Just wanted to check with you guys.
| All times are GMT -4. The time now is 12:15 AM. |
