help w/ gearing a lehner
ok when i get my mgm 80 n lehner 5300 what type of gearing should i start off with? any sugestions
Gear it similar to a 10 or 12 turn brushed motor to start with and adjust from there.
yea but im kinda new to this i dont know what you would gear a 10 t -sorry
Where are you going to use the setup first? then gear it as a standard brushed motor(as you would with a 9-10T motor) then you can gear it higher from that point. The 5300 will deliver you much more torque than a traditional brushed motor, but its better to treat it as a brushed motor at the beginning and when you feel that it needs to be faster just use larger pinions or smaller spurs and remember not to over do it.
If you have the manual for your vehicle, it should have some recomendations. What motor were you running before? What gearing?
ok i dnt have a motor in the begining bc i baught a flm pede off a guy on a fourm n im getting a lehner 5300 from mike and a mgm esc also im looking to run it in some dirt/sand/street/grass lol umm i do have the manual but idk where it is atm..
also it came w/ a p94 and had a spur n a pinion already instaled but idk what it is also has a steel idler if you need to know that too
What vehicle is this?
stampede
Start with a 10 - 12 tooth pinion on the stock spur gear, assuming you have stock size tires.
nope i got swamp dowgs
Close enough.
| All times are GMT -4. The time now is 04:34 PM. |
