Will the Mgm 60 Handle the Lehner basic 5300?
the lehner 5300 says its supposed to pull around 55 amps, but im not sure if i will run into trouble.
is a lehner 5300 / mgm 60 setup ok or not? and y? thanks. |
It might be a little difficult for the MGM 60amp to handle the motor, but on higher voltage and lower gearing it should be fine.
hmm. well i only have 6c packs and dont really have money for bigger packs
mike do u have any comment about this from experience or anything?
With adequate airflow and proper gearing, the 60 amp controller will work fine with the 5300 basic motor. Ideally, the 80 amp controller should be used with the 5300. The 60 amp will work great with the 4200 or below motors, but it will be challenged with the 60 amp controller, depending on several factors. I actually tested the 60 amp controller with a 5300 in my t3 and it worked fine, but if it was overgeared (by gearing selection or large tires, for example), it could get into thermal territory.
what is thermal territory (new to brushless). is that just overheating = causing problems?
i think i will most likely go with the 4200/60 then |
Thermal territory means the controller may thermal (overheat and shut down).
so its like protection to prevent problems when it over heats?
Exactly. It shuts down to prevent damage to the motor/controller.
| All times are GMT -4. The time now is 09:35 PM. |
