Fiegao brushless
I have a couple Feigao brushless motors- S,L 380C. Does anyone know which way they're wound Wye or Delta? Thanks, Don
Most, if not all, Feigao motors are delta wound if memory serves.
Thanks, they should work pretty good with a Mamba Max then. Don
Yes, that is the set up many members run.
Where did you found out that the MM doesn't run Wye motors?
The concern was mainly braking. There is another forum where a gentleman is running a MM on a 1/10 pan car with a Novak motor. It has been giving him some trouble. Don
the novak itself is the problem, not the winds.
| All times are GMT -4. The time now is 12:41 PM. |
