-   -   More traction to front wheels? (https://www.rc-monster.com/forum/showthread.php?t=684)
Dafni 06.10.2005 05:42 AM
Folks, what is a way to get more traction on the front wheels?
I think I need more on-power steering to be competitive with other MT's.
What are the possibilities to achieve this?
RC-Monster Mike 06.10.2005 07:33 AM
Stiffen the rear suspension.
Soften the front suspension.
Install a rear sway bar.
Smaller, thinner tires usually help as well.
Any or all of these may help you.
rchippie 06.12.2005 06:34 PM
What about changing the oil in you diffs ?.
RC-Monster Mike 06.12.2005 06:55 PM
Heavier oil in the front will usually increase on power steering as well.
braaap11889 06.13.2005 05:30 PM
More weight up front like a reciever pack mounted between bulks or on shock tower.
polarisguy6490 06.18.2005 10:01 PM
Try 30k oil up front and 20k in the rear that should be pretty good.
Rcbros 06.19.2005 07:26 PM
If your interested I would say consider the X-wing driveshafts.
Now the famous question... What are X-wings?
The x-wing driveshafts are a oneway driveshaft system similar to the rd quick turns
Quote from the maker
"These are very similar to the RD center one-way accept they replace the front driveshafts. The RD just dis-engages the front end where as our set up dis-engages the front wheels separately from each other. This will allow for maximum entry steering and with a 300K front diff, max pull from both front tires off the corners."
You run them with a locked front diff to achieve the best possible entry and exit steering. With a lock front diff, you have great exit steering, but will push horribly on entry. This is where the one ways in each axle (the X-Wings) come into play. They allow you to essentially have "zero diff" when entering a corner, allowing maximum entry steering
Think of it as this lol. When going into a corner and applying the brake each tire spins seperately. However with a heavy weight diff oil, as soon as you give the throttle its as if having a spool in the front, both tires will engage and you will shoot out of the corner
http://i18.photobucket.com/albums/b132/McCleary11/6.jpg
RC-Monster Mike 06.19.2005 09:29 PM
Wherdo you get these?
Rcbros 06.19.2005 09:42 PM
HEHE I'll tell your for a discount.
Check your pm's.
Rcbros 06.19.2005 10:00 PM
Keep in mind I do not have these. YET
I will get them asap. As I love a great turning truck!
Dafni 06.20.2005 01:52 AM
I made my own custom one way driveshaft! Works flawless and was an easy mod. But since I'm on buggy style shafts, I don't use it anymore.
PLUS: A one way front shaft does nothing for your ON-power steering.
Rcbros 06.20.2005 01:55 AM
may not for on-power but off power such as what you do in corners its excellent.
I;ll have a set as soon as I can.
Dafni 06.20.2005 01:59 AM
Sure, I agree. But right now I'm looking for on-power improvement.
I keep my self made shafts in my toolbox, and I might install it when I'm on a tight track, though.
crazyjr 07.10.2005 05:09 AM
you may could try lead weight w/double sided tape (like rc planes use for ballast)
nbcaznmaster 07.10.2005 08:44 AM
my freind is making somethign exactly like that!
