-   -   Lehner front plate popped off (https://www.rc-monster.com/forum/showthread.php?t=6851)
pb4ugo 05.20.2007 03:16 PM
I was running my CRT powered by a 1950/7 and 4s through a Mamba Max today. Had a pretty solid crash followed by grinding.
Ran over to it to see the motor seperated from the mount. First thought was backed out motor screws, but after looking at it closer, I saw the front plate was still attached to the mount and the rest of the can pulled away from it!
Anybody else have this happen to them?
Looks like I may be able to get it screwed back together, but I don't have time to try right now.
I'm starting to think the expensive electronics aren't worth it.
Serum 05.20.2007 03:21 PM
Everything has its braking point; the walls of the lehner motors are rather thin; it sucks that it happened though, most likely the case has got a small tear in it.
a Neu is build more durable IMO. (except for its open architecture.)
BrianG 05.20.2007 03:38 PM
Couldn't Mike heatsink clamp be used with the LMT motor? I know that the rear clamp may have to be modded, but it would help with it happening again...
pb4ugo 05.20.2007 03:44 PM
Yes everything does have it's breaking point, I don't think I should have reached it here. In replaying in my mind what happened, It was a loud crash (from the chassis bottoming out on a rock, and the motor popping apart and grinding on the mount), but not a bad one. The CRT is 100% intact.
I bought the Lehner just barely before Mike started selling the Neus.
pb4ugo 05.20.2007 03:49 PM
I don't see how it would help. I don't think you could mod the rear clamp enough to clear the plugs/solder bridges and the bearing/motor shaft.
I think I just need to go ahead and pay to have my own mount done. Lack of support under the length of the can, I'm fairly sure, is what caused this.
BrianG 05.20.2007 04:14 PM
Well, if you could solve the rear problem, you can use the clamp. Maybe some type of epoxy over the solder bridges to follow the "terrain" of the back of the motor, and then use a bar over that? Anyway, it was just an idea.
Yeah, supporting the rear of the motor would go a long way to help reduce the stress on the front. Maybe something like Mike did on the revo mount with a curved metal brace in the back...
captain harlock 05.20.2007 04:40 PM
They should've built the 1950s with a 4mm mounting holes just like the 22 series. Lehner must hear this call!!!
BrianG 05.20.2007 04:42 PM
I don't think that would have helped in his case. It sounds like the front plate was still attached, but the can came loose from the plate...
pb4ugo 05.20.2007 04:42 PM
The mounting holes in the front plate stayed put, the front plate popped from the can.
Sylvester 05.20.2007 04:45 PM
With my old 1950 i used mikes XL clamp and used button head screws with a thick washer and it held the lehner in place where the little clamp bracket goes.. just an idea.
pb4ugo 05.20.2007 04:46 PM
I do appreciate the input.
I designed a mount simialar to Mike's but had the motor laying flat on the chassis (since I had no intention of running a larger diameter Neu) but after getting quotes for a single piece and Mike coming out with his, I decided to go with Mike's. By the time I find an answer to making the clamp work, I might as well have the mount machined.
pb4ugo 05.20.2007 04:47 PM
Not following you. Pictures??
Sylvester 05.20.2007 05:01 PM
On the rear part of the clamp, where there are the 2 screw inserts, use a washer on each screw so there is contact on the rear part of the can and it will hold.
Serum 05.20.2007 05:30 PM
you could also use a layer of lexan to cover the aluminum and put some heatshrink around it to hold it in place. I don't think it's impossible to clamp the motor with the rc-monster clamp.
