NEW MT Proline Crime Fighter Tires
New Proline Crime Fighter MT Tire
More info Crime Fighter MT Part #1121-00 $30.00/pr. Features: · Narrow Carcass · Lighter design reduces rotating mass for greater acceleration · Foam Inserts included · Made from super-soft M2 compound Crime Fighter MT Part #1121-00 $30.00/pr. |
Nice.. They look a bit higher than the Komodo tires. Perhaps a nice compromise. Proline is working hard to make new products lately.
Finally! The Crime Fighters are one of the best rubbers for buggies.
The Bow Ties got company, yay! |
The only thing that would turn me away from these are the super soft rubber which means they wear easy. I have heard release dates from mid july to new week. I'm still waiting for the 23mm standard size velos to come out. I preordered both of them from a main hobbies. I can't wait.
so what did you order jared? the crimefighter MTs and standard velos? thats awesome. you know who will have to try them out:D
You can bet I will stock these crime fighters when they become available as well. i am always a suckers for a low weight monster tires, especially on ethat works (as someone already said, the crimefighter seem to work most everywhere on a 1/8 buggy, so the monster version should be ideal).
sweet will you run the crimefighters on them?
Pointless |
now that my truck is going on a deit, these tires are a must. i cant wait to try them. when is proline gonna come out with 23mm standard offset?
With those small tire diameter you don't need a 23 mm adaptor, because the stress is much lower.
No, an overkill in strength doesn't hurt.. they don't weight much either.
Those REVO rimms are known for the weak hexes. I normally glue my hexes into the rimms or use two screws that got thru the rimm. I really, really don't understand why they even made the large MT wheels with 14 mm hexes.. It is a weak link.. Proline rimms however are the toughest i met till so far.. with the 14 mm hex. (stablemaxx titans) and to continu the offtopic syndrome; do those 23 mm velocity rimms flex as much as the older 40 serie dishes? (those had the bad habbit to stay bent as well..) |
The stablemaxx titans are made by RPM. I haven't tried the new 40 series myself, either. I stopped running 40 series when I ran into the "wobble" problem!
| All times are GMT -4. The time now is 06:28 PM. |
