-   -   Brushless Wiring Question (https://www.rc-monster.com/forum/showthread.php?t=7145)
Thunderbruiser 06.11.2007 12:04 PM
Hey i thought you couldn't directly soldier wires to motor tabs but in rccar mag pros have theirs directly wired from esc to motor with no connnectors...will this destroy the sensorless mamba? i have 3.5 mm connects so i'll be using those but i was just wondering
BrianG 06.11.2007 12:08 PM
Who says you can't solder direct? That is always the recommended method, but makes disassembling stuff a bit more difficult.
Thunderbruiser 06.11.2007 09:11 PM
i read that on one of my older brushless esc's it said something about never direct link...unless i miss understood it lol
What's_nitro? 06.11.2007 11:10 PM
Hmm. Sounds like a bit of misinformation, or like you said, misunderstanding. Direct soldering IS the path of least resistance, and therefore highest efficiency and power. Although some type of silver solder works best IMO.
AAngel 06.11.2007 11:55 PM
Even if you don't direct solder, I'd get rid of those 3.5mm connectors. They have to lowest amp rating and loosen up pretty quickly.
