Need a new receiver
I have the Futaba 3PM-FM radio and my wire broke on my receiver, so I need a new one.
I currently have the Futaba R153F 3-Channel FM 75MHz, should I just replace it with the same one? Or, is there another one that is a better option. |
if it broke at the box and you can't solder close enough, open the box and solder the wire. You can even buy a new receiver wire if you don't want a soldered wire. http://www2.towerhobbies.com/cgi-bin...?&I=LXERH8&P=7 |
Good idea, it ripped off at the top of the Antenna Tube, so I would be able to solder it. Once I solder it, should I shrink wrap it? I lost the part that hangs from the top, so how long of wire should I solder on? I'm assuming a longer wire would be better.
Found a wavelength calculator, you can calculate the length of the antenna with http://www.qsl.net/haha/calc.html
I put in 75 Mhz, and it returned 37.44 inches. Does that seem long? Thanks!! |
http://www.futaba-rc.com/radioaccys/futl26.html Notice that is roughly the same length as the replacement wire I linked to earlier. Matching the wavelength might be good when you need every last foot, but is most likely overkill for most ground vehicles. |
I believe you can also do quarter as well. ;)
this helps, thanks everyone. I hope this is why it it glitching, it was running smooth.
| All times are GMT -4. The time now is 02:34 PM. |
