-   -   Bl (https://www.rc-monster.com/forum/showthread.php?t=719)
rc freak 06.18.2005 02:53 PM
Bl
I have a quesition for you which is faster the novak brushless maxx system with 14 cells or the 9920 esc with the 9L motor on 14 cells? That is with out changing the gearing. Could you tell me how fast they would go for example the 9L 45mph
supermaxx4190 06.18.2005 03:30 PM
the 9L/9920 will be faster than the hv.
rc freak 06.18.2005 03:32 PM
How many miles per hour does the 9l motor and 9220 esc with stock gearing on 14 cells with gp3300's
supermaxx4190 06.18.2005 03:47 PM
im gonna say about 40mph
rc freak 06.18.2005 03:51 PM
Ok thanks
Dafni 06.18.2005 04:03 PM
If you do the calculations (assuming stock tires, and 14 1.12V cells) you get 25mph in first and 41mph in second gear. But this is bone-dry hypotetical.
rc freak 06.18.2005 04:16 PM
Thanks for the calculations but what if I had a single conversion transmission?With the stock tires and 14 cells
Dafni 06.18.2005 04:23 PM
With the single speed conversion you will obviously only have one gear available, namely the second. You can vary gearing by changing pinions and spurs.
DAF
Nick 06.18.2005 05:10 PM
If you looking for speed I am sure there are some Lehner XLs that run faster on 14 cells?
Nick 06.18.2005 05:18 PM
Also, what are the Feiago XLs like? 7XL would be faster?
Dafni 06.18.2005 05:23 PM
Ja, I would like to know this too.
What can you expect from an XL on 14 cells? Which one would you take? 7L?
What temps and runtime?
Could you run it savely with the 99amp warrior??
rc freak 06.18.2005 06:01 PM
I dont know is there somebody out there that could help us out with this?
Serum 06.19.2005 04:35 AM
It can run on the 9918/9920, a person on this forum uses the 7XL on 18 cells with the 9918. Normally a big motor on low volts is not very efficient in the midrange power. (half load) it takes a highend motor (such as 2230/2240/2250 to become more efficient in this partitial load.. ) i know a person in Germany who ran his 2240/8 on a 9918 with great succes on 16 cells in a centerdiff converted, yet very heavy savage. Not recommended, but it's possible you won't burn your controller..
RC-Monster Mike 06.19.2005 10:57 AM
The 9920 can easily handle the 7xl on 14 cells. The 7xl will be very nice on 14 cells as well, but will need to be geared taller than a 9L for the same speed. I will do some running with a 1940/8 in my e-maxx soon(as soon as I get a 4mm bore pinion). The higher end motors, as Serum said, are more optimal fo partial load currents (althought they aren't cheap!).
Dafni 06.19.2005 12:36 PM
There's supposed to be an updated version of Wanderer motors soon. Apparently they should be almost equal to the high end Lehners, but much less expensive.
