-   -   Which 3S Lipo and charger (https://www.rc-monster.com/forum/showthread.php?t=7190)
ssspconcepts 06.15.2007 08:04 AM
Okay folks. I am getting ready to order my Lipos. I do not have a lot of experience in that departmentment and would like your advice. There are two brands that I am currently evaluating, but if y'all know of something better, please let me know. The two types that I am considering:
Flightpower 3S 5000mah 125-amp continuous
or
MaxAmps 3S2P 8000mah 160-amp continuous
Any recommendations on a charger? I want something that can eventually handle 5S and 6S packs. Maybe the EOS 1210i. Right now I have the MRC 977, which can charge two 3S packs simultaneously.
captain harlock 06.15.2007 11:11 AM
With no doubts go with the FlightPower 5000mah 3s packs. You should get a good charger like the MRC 989( charges up to 8s) and the FlightPower balancer with a 5s hi-rate
V-Balance harness.
ssspconcepts 06.15.2007 11:25 AM
V-Balance harness.
Thanks for the advice....So the flightpower lipos are better huh? Why are they better?
captain harlock 06.15.2007 03:59 PM
Factory built, prematched and prebalanced. Very durable during crashes and they hold much more voltage than any other lipos at high amp draw. Well priced, too.
ssspconcepts 06.17.2007 12:58 PM
Looks like my thread is dead in the water here....
Can anyone provide additionally opinions of what is the better 3S Lipo pack? Its not that I doubt the Captains good word....its just that I veiw opinions sorta like human intelligence (you know the U.S. Defense industry type-HUMINT). I prefer to base my purchases on multiple sources....
bdebde 06.17.2007 01:12 PM
I run the Apogee li/mn batts for my 3s rig, they work very well.
ssspconcepts 06.17.2007 06:40 PM
Thanks I assume you are using the 5800mah packs? Any problems with them getting hot with your Mamba Max ESC and 5700kv motor?
bdebde 06.17.2007 09:11 PM
I am using the 3800's. They do get to about 120 with the 5700, but only a bit over 100 when running the 4600. Of course I have a heavy MT2 conversion (5lbs) with 4 wheel drive geared for about 55mph on the 5700 (45mph on 4600). The 5800's should run cooler since they have a higher capacity.
