-   -   Will a 15t/46 on jammin CR overheat? (https://www.rc-monster.com/forum/showthread.php?t=7194)
supralover72 06.15.2007 11:23 AM
Will running a 15t pinion with a 46t kyosho spur stock tires BK wanderer/fegiao 8xl and 12 cells overhear a MM? I did Brian G's speed calculator and that puts me right where I want with speed.
Thanks.
MetalMan 06.15.2007 12:21 PM
I ran my Hyper 8 with an 8XL, 4s Lipo, 18/46 gearing, and a fan on the MM. It ran quite well. So 15/46 would run well also :).
supralover72 06.15.2007 01:05 PM
Thanks!
jhautz 06.15.2007 02:16 PM
Should be no problem. I have run much taller gearing than that in a buggy with no issue.. Just not with that motor. Id expect that you will be fine.
