gearing question
Hi guys.. a simple question about gearing....
51 spur/14 pinion : 3.64 center diff : 1:1 front and rear Differential : 3:1 so, 3.64 x 3 = 10.92 ? seem pretty low (or high?!?) I have an 8xl on 12 gp3900.... and with a 12 tooth pinion = 12.75... so right now I have between 10.92 an 12.75 final ratio... does is seem ok? auw = 8lbs thanks |
Sounds reasonable. I'm assuming a buggy??? If its a buggy the diff ratio is probably 3.308/1
What vehicle and how big are the tires. Tire size plays into the total gearing. |
hi jhautz, yes it's an crono prima 1/8 buggy.. (italian compagnie)
The total tire size 4 1/4"... I was just wondering cause I've seen some others thread talking about 20:1 ratio... but it depend on vehicule... :) |
I typically run between a 9.5 and 12.5 gear ratio on my buggy. So what you have posted sounds good to me.
| All times are GMT -4. The time now is 12:18 PM. |
