proving BL is more powerfull than nitro!!
i was just driving around my street doin some speed runs and my front right tire was balooning like crazy and here are the results! :eek:
only problem is i need a new rim!!!!!:031: i dont ever recall doing this with nitro!!:005: http://i86.photobucket.com/albums/k9...2/DSC00906.jpg http://i86.photobucket.com/albums/k9...2/DSC00908.jpg |
Step up to 23mm dace adapters and your problems are over.
Im guessing a 8xl on 4s did that? lol
actually im running 18cells rsgp3300s... ik its stupid lol but my lipos dont come in for another week and i wanted to drive it!!
i have a bunch of 23mm adaptors and tires (not dace) but those are for when i go to the track. these are just my street tires... i might have to upgrade the rims to 23mm though! |
You can use ca glue or jb-weld to make a 14mm sit snug in the rim, i used to use ca glue on my savage, the thing is that you are better off with aluminum hexes, drill two holes in them and use two M3 screws that fit in the rim (you need to make two slots in the rim to have the screws go through
I ultimately went with the 23mm hexes for my MGT too. I stripped out two sets of stock MGT wheels and tires. Brushless is some pretty wicked stuff.
I should also mention that I now break the pins in the axles, but those are cheap. |
lol wow i would have never thought to break the pin!! hahah! ya i have a bunch of those...
i will try that serum!! thanks! |
| All times are GMT -4. The time now is 07:28 PM. |
