Looks like Lipo really is the future according to Novak
I found this this morning, http://forums.radiocontrolzone.com/s...d.php?t=239086, has cut off for 2s and 4s lipo, depending on how you wire it
hmmm... funny, i've been thinking of using my 6.5 esc with my lehner to see how that combo works together. :005: my hv system is just laying around as a spare system - i may have to solder the 2 together and see how it works.
nice that the new esc comes with the lipo cutoff. |
won't work, the novak is sensored the lehner is sensorless
Is it me or is it just the old hvmaxx controller with an external fan and an external LVC included? (novak 5471)
http://www2.towerhobbies.com/cgi-bin...?&I=LXPGN1&P=7 |
i thought i've read before that sensored systems can run a sensorless motor - just not the other way around.... ?
other way around. a sensor based motor can be used on a sensorless controller, since you are not using the sensor wires. A sensor based controller doesn't use the EMF to determine where the n/s poles of the rotor is located, it uses a HALL sensor.
ahhhh, ok. thanks guys.
I am curious about this because I have a Novak motor that I would like to use, but the ESC does not work. And I would like to try the motor with my MM. Does anyone have any experience with this, or is it just a common knowledge thing? |
Are the Novak motors built the same way as the Neu's? Are the symptoms similar?
Thanks for the info, I will check out that thread and give it a shot. |
service replacement options |
http://www.rctech.net/forum/showthre...&page=43&pp=30 |
| All times are GMT -4. The time now is 04:59 PM. |
