-   -   Center Dog bone fit? (https://www.rc-monster.com/forum/showthread.php?t=7339)
mkrusedc 06.24.2007 12:32 AM
I installed 70mm center dogbones in my E-maxx. There seems to be alot of play in them. The pin sits just short of halfway into the cup. Shouldn't it sit in the deepest 1/3? Is this normal or should I get some a little longer?
http://pic20.picturetrail.com/VOL143.../261478296.jpg
GorillaMaxx360 06.24.2007 01:05 AM
put a piece of fuel tubing inbetween the ball and and ball cup and that will not allow for so much play and you will be good.
GorillaMaxx360 06.24.2007 01:07 AM
you could get 72mm if you wanted but fuel tubing(spacers, washers, orings) is cheaper and will do you the same performance.
mkrusedc 06.25.2007 01:13 AM
Thanks. I am learning that fuel tubing can be used for alot of things in an electric RC
mkrusedc 06.25.2007 01:16 AM
Would these work?
GorillaMaxx360 06.25.2007 11:41 AM
it does not say the diameter so they may be small but they should work. any type of spring will work too. try a pen spring and cut it to size. anything to shim the distance really will work.
