Any news on the slipperential?
I realize everyone is busy with rebuilding the forum and i'm not pushing, but any News on the V2 of the slipperential for revo's? if possible I'd like to have one before the bash
I can handle that. hey that could be a contest, slipperential building and installation, winner gets theirs free
^I'm in!
Whatever happended to the adjuster-slipper-differential, the one which you could tighten/loosen by hand? Or is that part of the V2 design?
there is a slipper diff being worked on, But i'm more intrested in the slipperential
Both are worth the wait.
What about a slipperential for the FLM chassis? |
Slipper for the FLM? Man, again, I have been away toooo long!
LOL, it just might happen.
When they are available, i need two. one for the Gmaxx to upgrade, one for the revo to get away from the tranny and a V2 Motor mount to use the V1 slipperential in MGT conversion
Can't Mike work on a slipperential with higher gear ratio?
The normal slipperential GR is 2.2:1 which really makes the truck feels slow. I need something like 1.5 or 1.7:1 to make the truck feels a bit fast. Even with 6s, my truck does rip, but not fast enough. |
if you can find room, you can fit a 46t spur and an 18t pinion. What pinion are you currently using on your motor?
But isn't this gonna make the rig slower?
I thought about 24 pinion and 40T spur. |
Wait, can I only use the V1 with an MGT? Or can I use the V2 with an MGT?
| All times are GMT -4. The time now is 06:43 AM. |
