Duplicolor Metalcast, anodizing in a can...
Has anyone ever used this stuff on rc? It's been out a while and I was wondering if it's good or not.
http://www.duplicolor.com/products/metalcast.html http://www.duplicolor.com/products/metalspecks.html |
I honestly think its just a candy paint. When painted over aluminum, etc. it will look anodized to an extent. It will still look like paint I think. Mainly because paint is usually glossy, where as anodized is usually kinda flat looking.
Really? It doesn't look that glossy in the pics. Thanks.
It's just a thought. I'm not positive, but it's a safe assumption. You can get it at Walmart I think, so I would pick up a can and try it. I might try some purple or orange now that I think about it.
Yup, I will next time I'm there, thanks. I'll let you know how it goes.
I tend to like the "hammered finish" paint on Aluminum. It is semi-glossy and creates a texture to hide many minor imperfections. See my BL Conversion link in my sig to see the results.
It does chip off eventually, but so will any paint. I use regular flat paint as a primer (regular primer doesn't stick as well for some reason), and then only a light coat of the hammered paint is needed. Otherwise, you see the Al through the little pinholes the hammered paint creates and you'd need multiple coats. |
Thanks for the tip. Does it come in red?
I don't know. I usually choose darker colors, so I don't remember seeing other lighter colors. I'd imagine they should.
Yep, I use a fine steel wool and thoroughly scuff it up, and then wash with dish soap and water. That gets all the fine metal dust and grease (fingerprints) off the surface. I suppose denatured alcohol would work too.
Denatured Alcohol helps to make sure you've gotten rid of any residual oils, like from your fingers, and any other chemicals that may impede a good adhesion.
Thanks for the help guys!
| All times are GMT -4. The time now is 08:05 AM. |
