FLM Bulkless (Run dry or oil em?)
hey guys i picked up a set of FLM bulkless a while ago and its time to put em in. i recieved them without oil or grease.
do i run these dry or do i put diff oil in them? any suggestions for wt? i'll just be bashing. i have titans but most likely getting the novak 4.5 |
The diffs (ringgear/pinion) are used with grease, the internal gears of the diffs are used with silicone oil.
Thread moved to FLM. |
thanks for clarifying serum
I use White lithium grease on the ring/pinion gear and Ofna Green Stuff Differential grease for inside the diff cups.
http://www2.towerhobbies.com/cgi-bin...?&I=LXESC0&P=7 |
I use Protech Speed greese on pinion/bevel gears and oils inside.Oil can completely change handling of the truck. After trial/error i ended up with 7k in front and 10k in rear.
That green stuff is a horror for (most) o-rings. with 1/8th diffs, you are better off using silicone inside the diffs.
| All times are GMT -4. The time now is 03:46 PM. |
