-   -   Lipo receiver pack.... (https://www.rc-monster.com/forum/showthread.php?t=7520)
captain harlock 08.31.2007 03:05 AM
Guys,
If I use a 2s1p 7.4v lipo receiver pack, would not this destory the servo and receiver?
I thought I would try a EVORX 1300mah pack on my Futaba receiver/ servo, but I'm afraid that might destroy them.
An external bec would be nice, but it's quite a mess to solder it to the controller and then connect it to the receiver.
I don't mind charging a receiver pack every time it dies.
Thanks,
Alawi El-Jifri =)
wallot 08.31.2007 04:51 AM
robots use 7.4V for servos so some servos can handle 7.4V as well some recievers. have a look into its specs. if not you will have to usevoltage regulator (UBEC will do nicely)
biddy 08.31.2007 06:03 AM
if you get a dimension engineering sport bec, you only have to solder the wires to the ESC battery leads...very clean. you don't even have to disable the BEC in the ESC.
i don't think your receiver/servo will like a 2s LiPo pack. the peak voltage of a 2s pack is 8.4v whlie the peak voltage of a 5 cell Nimh RX pack is around 7.3v.
captain harlock 08.31.2007 06:30 AM
Yeah, so I think it's a bad idea.
Thanks guys.
