-   -   Has anyone ran a Neu 1521 in a G3R? (https://www.rc-monster.com/forum/showthread.php?t=7616)
hyperasus 09.06.2007 05:31 PM
At 3.3" long would a 1521 be too long to fit a G3R?
hyperasus 09.06.2007 06:24 PM
Nobody? Thats surprising.
Anyone know if the 1521 has a normal bolt pattern and 5mm shaft?
gixxer 09.06.2007 06:53 PM
I run a 1521 1y in my 8t. The bolt pattern is normal and it has a 5mm shaft. Not sure if you have enough room on that chassis though.
crazyjr 09.06.2007 07:42 PM
If i'm right, that motor has 6mm (1/4") longer than my 1515, wow you are going to have a time holding the front down
gixxer 09.06.2007 08:14 PM
a 1515 is listed as 2.7" and the 1521 is 3.3", so its .6" longer.
hyperasus 09.06.2007 09:28 PM
Can someone with a G3R and slipperential measure and see if a 3.3" motor will be too long?
gixxer did you get your 1521 from Mike?
lutach 09.06.2007 09:28 PM
They use a 4mm bolt as well.
