-   -   Mm-8xl Problem (https://www.rc-monster.com/forum/showthread.php?t=7630)
C-5Quad 09.07.2007 12:04 PM
Mm-8xl Problem
Im new to brushless and I have a MM on a 8xl with an external bec and I disabled the MM bec
when I turn it on and program the remote all goes well I think...then if I hit the throttle past 1/8 the motor doesnt work right it seems to be fighting itself studdering something horrible
I tried switching the motor leads around but no luck
can someone please help
BrianG 09.07.2007 12:25 PM
What kind of batteries are you using and what voltage? Even CC says that insufficient batteries can cause the symptoms you describe.
Also, check all connections (motor and battery) for tight fit.
Does anything get hot?
_paralyzed_ 09.07.2007 01:40 PM
I love it
ha ha i'm a c-5,6 quad myself!!! woot woot! what you're describing is cogging, if you give it a lil kick does it take off?? more voltage or a smaller pinion is the answer
C-5Quad 09.07.2007 03:30 PM
the motor is doing this with no load...no pinion....12 cells just to test...I plan on running 14 cells...I called castle they said it might be interference from my bec...its 1" from the reciever....I will move it and give it a try when my hands get home from work....aka...my dad
