-   -   Need advice on a setup? (https://www.rc-monster.com/forum/showthread.php?t=7652)
mkrusedc 09.08.2007 02:52 PM
I have an E-Maxx with all appropriate drive train upgrades. Mostly RPM plastic to keep my weight down. I purchased a Neu/1y/1f motor and tried to use it to with my existing MM and 14 cells. The voltage was too high. I do have two TrackPower 2s1p packs that I have not opened yet, but could probably use with the MM. I plan on purchasing either a MGM 224/18 or a 160/18 because I can not tolerate the cogging.
My question is should I open and use the TrackPower batteries or because the MGM can handle more get a 6s or 18 cell batteries? My current gearing is 52/17. I wanted at about 40mph for bashing. The bigger batts according to Brians speed calculator put me abouve 50mph. If I went with the bigger batts I could get a heavier extended chassis for better control or smaller batts and stay plastic?
AAngel 09.08.2007 03:36 PM
The 1515/1Y on 6S is going to be too much in my opinion. More voltage is usually a better thing, but I'd get a lower kv motor to run on that much voltage. The 1515/1Y on 4S is about perfect in a truck. On 5S it gets to be a bit too much. On 6S I think that it would be way beyond practical.
My everyday setup in my 8ight T is a 1515/2.5d on 5S. Geared 18/48 with Proline Badlands MT tires, I clocked it at 50 mph. It's a lot of power and speed for a truck. For 6S, I'd get a motor with an even lower kv rating.
Since you already have the 1Y, I'd just run the 4S setup and maybe get a 5S pack later for occassional insanity. The 1Y is a good motor and the Compro stays very cool.
mkrusedc 09.08.2007 04:13 PM
Thanks. That is they way I'll go. I just charged my batts and ordered the 160/18 from Mike. in 2 days they'll be no cogging.
mkrusedc 09.09.2007 01:52 PM
:surprised: After reading your post I thought if i can get 6s why not. Well, 4s alone is insanely fast. 6s in a an E-Maxx is just stupid for a basher. I may as you suggested try some speed runs with a 5s. thanks for helping this noob out.
zeropointbug 09.09.2007 02:14 PM
Yes, good choice on the MGM controller, they are great esc's!
6s lipo will be 2x as powerful as 4s lipo given the same motor, your rpm will go up 50%, and torque curve 50%.... 2x as powerful, in other words yes, stupid-crazy-insane-retarded fast! :surprised:
