RC-Monster Brushless Heatsink/clamp
Any one know what size I need for a Lehner 1950\7 turn?:neutral:
The clamp part won't fit over the end of a standard lehner. It may on the hi-amp version, you would need the XL.
i have a 1940/7 hi amp with a RCM heatsink. i don't have the end clamp, as my heatsink is longer than the motor (i must have the XL heatsink).
i'll measure tonight. http://pic20.picturetrail.com/VOL127.../277309185.jpg |
I guess I have some engineering issues to work through.
Do you really have to clamp the Lehner's? There isn't any danger of them pulling apart like other motors. If anything I would clamp around the circumference to maximize heat dissipation into the heatsink. Some type of thermal grease would help too, if it isn't there already.
the heatsink was designed specifically for the feigao's, because the end is known to pop off. that won't happen with the lehner, if you want it for looks just leave the clamp part off, otherwise, any heatsink will work really, you'll really have to work to get that lehner hot enough to need a heatsink
My main issue is heat. I wanted it for the heat sink. Not the clamp. I will look into using other heat sinks with thermal glue.
Somebody else is using one with his Lehner by leaving off the back cross piece and using two washers and socket head screws instead to retain and put tension on the rear.
The Lehners won't pop apart easily like a Feigao, but the front has been known to pop off a time or two on some even though they are threaded on. |
Hickery, got any pictures of your truck?
http://www.espritmodel.com/index.asp...OD&ProdID=2077
This heat sink works perfectly on the lehner motors. I'm using one on my 1930 in my LS10. Although, it really doesnt need it. The lehners run cool. If I ever take the motor out for maintenance I'll probably just take the heat sink off and save the weight. Heres a link to my LS10 thread if you want to see it installed. http://www.rc-monster.com/tempforum/...highlight=ls10 |
My Lehners (1930 and 1940) seem to run about the same temp with or without a heatsink. I probably have enough mass at the motor mount to remove enough heat there.
| All times are GMT -4. The time now is 03:30 AM. |
