Best Data logger?
I see some guys have the eagle tree data logger for getting amp draw and battery voltage etc... Are there any other ones out there that are a better option? I see Eagle tree has a few different loggers. Whats the best for our 1/8th scale conversions?
Eagle Tree all the way. I dont really know of any other data loggers, except for the blackbox thing that goes with the newer MGM escs. I heard Novak was working on one too, but dont know anything specific about it.
the blackbox problem is that it does not work with car ESCs, micrologger is small, cheap and does its job well
I'd say Eagletree microdata logger as well, I got the BNB DPR 150 2 and it doesn't work as well as it should, I got problems getting it to work (only works on my laptop (sometimes). but the eagletree works every time anytime and easier to load in the computer. Only problem is its limited to 100 amps max, A few of us have seen higher but they say it voids the warranty
Thanks guys, ill look into the micro logger.
I have 110Amp peaks on my micrologger and no problems at all.
it must be maxx amps of my truck as it needs about 1900W for acceleration from standstill and it was like 110@17.2V with 5S lipo and 100A@19V with 16 fresh intelect cells :)
Most i ever pulled was 124amps, on a Micro logger
My eagletree V2 seems to cap at 140A
I've had 140A spikes close to each other in a run with different voltages, which suggests to me that at least one of the spikes was over 14A but logged as 140. |
| All times are GMT -4. The time now is 10:53 AM. |
