Project B-S
Project B-S is my Brushless Savage. Ill post up some images and my progess and talk about it later.
In the Beginning http://admiraldog.digital-flo.com/savage/108_0852.JPG Fiegao 9l 5mm Bigbore http://img189.echo.cx/img189/7862/10808934zg.jpg Mock-Up motor mount http://img237.echo.cx/img237/707/1090904small6ag.jpg Finished motor mount http://img299.echo.cx/img299/3192/1090922small6ki.jpg Finished motor mount http://admiraldog.digital-flo.com/savage/109_0926.JPG Triangle Series Battery connecters http://admiraldog.digital-flo.com/savage/109_0932.JPG Mock-up, Half inch spacers for Battery Holder http://admiraldog.digital-flo.com/savage/109_0939.JPG Mock-up, Half inch spacers for Battery Holder http://admiraldog.digital-flo.com/savage/109_0944.JPG Finished motor mount In savage http://admiraldog.digital-flo.com/savage/109_0947.JPG Finished motor mount In savage http://admiraldog.digital-flo.com/savage/109_0948.JPG |
Nice work!
My friend.... :D
i finished my battery mounts and put them on and all, and finished a few other things so i could ATLEAST get a speed run out of it. Well i did. It was going pretty fast for FIRST gear. It wont shift. I have no clue why it wont shift into second. Anyone got an idea?
Perhaps the pawl is tightened too hard.. Or the pawl is stucked inside the aluminum part.. does it shift with the wheels spinning free in the air? (note; with electric you allmost don't hear it shift)
Did you tried adjusting the shifting point? with BL you can keep that point very low. (make it shift into 2nd at 15 mph or so) |
My set screw was out. Fixed it, put thread lock, and it all works now. Thanks
I finished! well almost, still gotta make the speed control mount, and buy some velcro straps. But you get the idea.
http://admiraldog.digital-flo.com/savage/109_0968.JPG http://admiraldog.digital-flo.com/savage/109_0969.JPG http://admiraldog.digital-flo.com/savage/109_0970.JPG Ill get an article up soon. I wont be on for a few days, going to the beach to test this thing out. ill tell you how it is. |
Be carefull with those batteries touching the aluminum, i don't know what that orange stuf is that lies underneath them, but the batteries may not short with that aluminum. They can catch fire if they do. You mounted your motor nice and low..!
Looks good! Should be an incredible basher.
I use clear shrink wrap on my batts. Protects them and looks clean, too. |
im going to shrink wrap my batteries, and put plastic dip on the aluminum. and also use velcro. So it will look much cleaner.
http://www.admiraldog.digital-flo.co.../109209823.jpg
Just got back from the beach, Got loads of pics. http://www.admiraldog.digital-flo.com/savage/beach/ Dial ups, be caution. |
how fast is it?
on 12 cells it can run a 30-35 mph. and with an impressive acceleration as well, because of it's 2 speed transmission.
on 14 cells im hoping it will go 40-45 geared 13/49
Not with the stock tires.. They will balloon badly and put some serious stress on the drivetrain, because of the difference in diameter of the front/rear tires. it will need some serious playground to run it. Those tires get unstable at 40 mph+
| All times are GMT -4. The time now is 04:29 PM. |
