E-Maxx, 3600XL, 12 cell gearing combos?
Hello Guys,
I'm new here and I've been reading some of the combos being run. I have a 3600XL I would like to try on 12 cells and wonder what gear ratios to try. A good base line is what I'm really after. Thanks, Paul. |
What controller are you using? Don't gear it too high, because the 3600 is a hot motor!
Hi Serum,
Paul. |
What are you doing with the truck? Bashing? racing? waht terrain? The 3600 is a bit hot for the maxx(although they are loads of fun!). Look at around a 13 tooth pinion on the stock spur. the 8s is hotter for sure, but really has no business being run on 12 cells in an e-maxx!
honestly a 3100 is a tad to hot. yesterday i swisted a stock slider into a pretzel. literally.
I used to race with an xl3600(couple years ago). It is warm, but the power is very nice. I would get a heatsink and a fan and it will be a great, powerful setup.
honestly, powerful is an understatement
Hi Guys,
Well, as far as what I do with the E-Maxx I race it every once in a while and bash with it more often. I generally run on dirt/clay with some grass running now and then but not very much. I did a search and the 3600XL kept popping up as a good motor on 12 cells but maybe there is a better option? Here's a list of motors I have, maybe someone could give me an idea of a better combo. BTW: the 8S is run on 8 cells, pretty quick and has won me several races. The only problem is it's hard on the batts so I'd rather run the 12 cell packs and reduce my current draw a bit. Lehner; 3100XL, 3600XL, 4200XL, 5000XL. I also have a 2280/11 but I think that's a bit much for an E-Maxx, lol. Hacker; 6S, 7S, 8S, 8L, 14L, 13XL. Aveox, 36/30/1.5 That's about it for the stuff that would bolt into the truck, the rest of my motors are a bit to much for the Maxx. Thanks Guys, Paul. |
Hey Guys,
Here's a pic of the truck, it weighs about 10 pounds RTR. http://www.skullcaps.com/boats/emaxx1.jpg Paul. |
The 2280 would be my pick!!!:L: If you are going to stick with 12 cells I think the XL 3100 or Hacker 8L would be a better choice. Nice collection of BL motors!
Thank you, Promod |
wanna get rid of one or two?
definately the 2280/11 on a 18s lipo pack......but you might want to upgrade the stock sliders......:eek:
seriously though....I would go with the combo's promod recommended |
Promod took the words out of my mouth. The Hacker will need something to prevent the can from popping(like my heatsink/motor clamp), but both will peform excellent(and similar). the Hacker will run cooler and have a bit more torque, but also will likely have slightly less runtime(very slightly less). Nice motor collection, by the way!
Nice collection indeed! You're into planes or boats, right?
2280... No doubt..
I'll get my toolbox.. |
| All times are GMT -4. The time now is 10:39 PM. |
