My kliiMaxx
Hi all!
I have put some parts in my maxx.. -3.3 conversion -FLM diff cups -FLM bulkheads -FLM skidplates(f/c/r) -Traxxas big bore aluminium shocks -Integy's aluminium shock tower's -MGM 16018 esc with fans -BK wanderer 20XL06 motor :rofl: -Maxamps 2s 8000mah lipos ( 2pcs ) So this is my setup now..i will buy gorillamaxx set someday.. I have ordered Lehner 1940/6 motor to my maxx...cause bk will heat up too much even i have short gearing.What should run be with setup i use now?in series?I wonder if i order 3s lipos(8000mah) and run them in parallel connection...probably enough speed but longer run time :neutral: pic's coming ...:yes: |
Welcome to the forum Hotti;
Your setup is very hot! that 6XL motor will get hot rather soon; use a tempgun to know what temperature it's running at, the 7XL is hot on 4S, so the 6XL will be even hotter. I ran my 7XL on 3S and it was great fun for bashing. (and the temps where fine too) This might be an interesting read; http://www.rc-monster.com/forum/showthread.php?t=5115 |
Ok..i will read that..
I have now 18T/64T gearing.I use venom smart temp.Yesterday i ran whole batteries and venom says that temps were 49'c.Not hot at all:wink: |
Boy, you have a lot of power it this.....Cool vid!
Thx mate..
Some pics from todays action..
http://i15.photobucket.com/albums/a3...la61007007.jpg Bigger is better.. http://i15.photobucket.com/albums/a3...la61007001.jpg http://i15.photobucket.com/albums/a3...la61007017.jpg |
Sweet!!!!!!! Those are some mad driving skills. What settings are you using on the speed controller?
I am seriously impressed by that truck. When you are doing speed runs like that I would say lower the suspension as much as possible, should help with stability and cut down on the wheelies a tiny bit. You are going to need a bigger wheelie bar though, that is some crazy power....
Thx mates..more power to come with lehner 1940/7 :whip:
Esc setting: Car mode <-> light brake auto timing reduce rpm 4s li-xx free wheel no brake at neutral no auto correction Like that...Yesterday with 20XL07 feigao the temps where about 50'c...:diablo: |
50*c, thats cool as a cucumber. You've had no issue with setting up the MGM correctly or cogging etc I take it?
Ömm?Could tell it "easier" cause my bad english skill?:oops:
:lol: I mean, you had no problems programming the speed control or anything like that?
Hehe...ok neil..now even I get it :yipi:
But but.. I had some major problems with esc at the beginning.. First it worked ok(the very first run).Then i tryed to programmed it to use with nimh cells.When i put nimh's on and turn the power on esc starts to beep beep beep....beep all the time.Even i put the default setting in it still beeped. But when i had put default in about ten time in row it started to workin :yipi:..Now if i have run with lipos,i programmed it with lipos to use nimhs.then when i have drived with nimhs and want to use lipos i program it with nimhs.This way it works perfectly.Love the esc. First i programmed it with transmitter, but now i have usbcom+ and CC02 cable so I can do it now with pc :whip:Much easier and safer. So.. I have had problems with rear driveshaft's..they wont hold on..wonder why :whistle: :rofl: :whip:..Well..i had revo some time ago and had some parts left on it.So i modded revos drive shaft to fit my kliimaxx on the rear..Revos are much stronger,hope that will hold. Pics with mod maybe tomorrow. |
It seems alot of people are having issues programming the MGM esc, so you are not alone. As for driveshafts, the stock emaxx ones dont last very long as you discovered- tmaxx 3.3 shafts, knuckles and turn buckles should be fine though.
| All times are GMT -4. The time now is 02:33 PM. |
