-   -   Dimension Engineering Park BEC works great w/Mamba ESC in Rusto (https://www.rc-monster.com/forum/showthread.php?t=7927)
snellemin 09.30.2007 05:29 PM
I had purchased a Park BEC from Dimension Engineering to run with my Mamba. I am running 9.9 and 13.2 volts and felt like the mamba linear BEC couldn't take it very well. The mamba ESC is a bit cooler now with the internal BEC disabled. Used it at today's dragrace and had no hiccups. It's installed right behind the Servo.
http://i189.photobucket.com/albums/z...r/DSCF1128.jpg
http://i189.photobucket.com/albums/z...r/DSCF1124.jpg
http://i189.photobucket.com/albums/z...r/DSCF1122.jpg
BrianG 09.30.2007 06:08 PM
Yeah, I tested that BEC a while back and posted the results. I was quite pleased with the performance and think it will work very well for the smaller/lighter vehicles. However, I would use the larger version on 1/8 scale and up, or on setups over 8lbs due to the servo needed.
snellemin 09.30.2007 06:14 PM
Ah, I couldn't remember who posted the BEC results. All I remembered was that it had a good indepth technical review on this forum. I have the Park 5V BEC. This thing is so tiny.
BrianG 09.30.2007 06:27 PM
Yeah, that's the one that I tested. Did you mean "in depth" or "inept" testing? :smile:
snellemin 10.01.2007 01:28 PM
sjooks!! I corrected the grammar.... hehehehhe
