-   -   What do you think of this setup for e-revo? (https://www.rc-monster.com/forum/showthread.php?t=7929)
david lamontagn 09.30.2007 08:19 PM
I've a brand new feigao 12L siting here, and i plan to try it on my revo conversion. I'll keep the 2 speed tranny, and run it with 5000 mAh, 4s li-po.
Do you think that this motor will be OK for my revo or should i order a XL motor instead??
thank you guys:intello:
BrianG 09.30.2007 08:23 PM
With the 2 speed; yes. Having two gears will work the motor less. You should use an XL for a single speed just because of the greater start power needed.
david lamontagn 09.30.2007 08:29 PM
OK so i'll give it a try. The only thing is the 2 speed, don't know if the gear will hold the shift with brushless power:gasp:
I'll loose the slipper...........
BrianG 09.30.2007 08:32 PM
Yeah, I was concerned about that too. The 2nd gear clutch only engages the gear on one spot and that spot is a measly pin embedded in plastic. I wasn't sure if it can handle the snap that BL power can produce.
david lamontagn 09.30.2007 08:43 PM
That's for this reason Brian that i've thin to use the Robinson hardened gear set, the pin for the second speed is plant right into the steel. Much more solid, no?? :neutral:
lincpimp 09.30.2007 08:56 PM
My friend had a bl revo running a 8l on 3s and the 2 speed. It ran fine, so the 12l on 4s should be ok. Go up to the xl if you want to go single speed.
