-   Mini truggy (https://www.rc-monster.com/forum/forumdisplay.php?f=43)
-   -   CRT.5 Bruushless 1:12th ompetition indoor truggy (https://www.rc-monster.com/forum/showthread.php?t=7960)
Thomas P 10.03.2007 10:51 AM
Finaly it is done...will only use this one for indor use..since the 1:10 wd car is little to big for our track, this will fit perect.
MEGA pinions
RC-Monster Motormount
GTB
7.5r motor SIntred
E-Power 2s Lipo 3600 20-30c (190 grams)
http://i123.photobucket.com/albums/o...5/S5030223.jpg
http://i123.photobucket.com/albums/o...5/S5030224.jpg
Done...
http://i123.photobucket.com/albums/o...5/S5030228.jpg
http://i123.photobucket.com/albums/o...5/S5030225.jpg
I tested this one, just this morning with 6 cells, ELITE 3600mah Nimh the car have GREAT torque, topspeed is perfect for the indoor track... will pick up my Lipos in a hour or 2..3600mah 2s 20-30 series from E-Power... Painted body, and a finish truck will come this weekend.
jnev 10.03.2007 07:00 PM
Looks great!! Seems to me that you have got a perfect spot for a square battery pack right behind the ESC. :smile:
rchippie 10.03.2007 07:09 PM
Please keep us up dated on how the NOVAK system works for you. I have intertaned using a novak system if i was to convert my crt.5.
david lamontagn 10.03.2007 07:19 PM
I want to remove my nitro engine and re-install a brushless in mine too, but i've a feigao 8s can, and i think to buy a 7.4v 3700mAh flightpower li-po, but not certain about a 7.4 volts setup in this truck.
Is i'll get a good power and good runtime:neutral: I've always had 3s or 4s system, don't know anymore about 2s setup.
Thomas P 10.04.2007 11:17 AM
Update.. Nitro is fun, but cant use that indoor :D... Talked to a machine guy(orwhat ya call i) he works with metall and CNC etc... he will DO a carbonfibre chassi for me, and a front bulkhead in Dural alu, Alu 2024...
Will post pics later on that, just bought the carbonfibre plate.. Costy as XXXX FG´s 3x150x350 mm
http://i123.photobucket.com/albums/o...5/S5030231.jpg
The little ive tested the car, say app 2-3 min full trottle away then back, the pack wasnt warm..the motor cold... GTB/7.5r Sintred
Thomas P 10.07.2007 09:23 AM
So i did some tracktime...4 packs after packs, the motor temp wasnt higher then 33 deg celcius, Lipo 37 and ESC 20..th car reached topspeed after app 3 meters...il go up one more T on pinion t 14T for outdoor usae..indoor il think this combo will be perfect
http://i123.photobucket.com/albums/o...5/S5030259.jpg
http://i123.photobucket.com/albums/o...5/S5030256.jpg
Short run only testing...
http://i123.photobucket.com/albums/o...h_S5030250.jpg
