brushless noob
Help me with this, i'm new too brushless and I'm on a budget. Im thinkin' Warrior 7018 controller and a feiago 8s motor on eight cells. What do you guys think.
By the way i'm putting this on a pede. |
sounds good i got a pede also but im gona go with the 8s and the mgm 80 amp esc be a lil while need a lil more cash
:M: |
I have the 8s and 7018 in mine. You'll also want to add a receiver pack as well, mounted over the front wheels is a good spot for it. Helps to keep the front wheels on the ground a little better. You'll also want to add a small cooling fan to put over the ESC to keep it cool.
With 8 cells, the receiver pack isn't necessary. The fan is always a good idea, though.
Hey Thunderwolf,
how many cells you use and whats your run time? |
| All times are GMT -4. The time now is 09:06 PM. |
