-   -   5s with mm ? (https://www.rc-monster.com/forum/showthread.php?t=8045)
speedy 10.08.2007 05:16 PM
5s with mm ?
Hi !
Hi can i use a 5s lipopack in a 1/8 buggy that weights 3600g rtr ? using my mm esc ? or will it burn ?
AAngel 10.08.2007 05:21 PM
It really depends. Some will do it and some won't. Those that will do it, from what I've seen, run ok with mild gearing. If you get too heavy on the gearing, it will start cogging. If it does, back off of the gearing.
Although I do treat my MM controllers badly, I did blow up four or five of them running 5S. Even if you can get away with it, you would be better off with a proper controller. Many have been having success with the Compro line of controllers.
bdebde 10.08.2007 09:36 PM
I would stick to 4s on the MM, unless you don't mind risking burning it up.
BrianG 10.08.2007 10:19 PM
From all the reports, only one of the earlier batches will run 5s, but can be finniky as AAngel stated. I too would stick to 4s max.
