Actronic 120?
first, I just found out about this controller, and the only person I know is familiar with it is lutach. sooo lutach, tell us about it. I tried looking for more info on google, and found the thread that you bought your controller in lol.
but have you run it yet? any idea if it'd be car compatible? what makes it a heli controller? did you ever find instructions? https://www.fxaeromodels.com//produc...oducts_id=3183 looks like a good hv candidate. |
It is an amazing controller. It uses the same FETs as the Schulze 40.160. I did use it in my MBX5T, but had to stop due to a glitch and/or interference. It only has one option for car and that is to put a jumper in the "REV" location. You will only have forward/brake/reverse. It works like it's supposed to. You will also have to do a throttle calibration every time you go running. I think this was done in order to use full throttle and full brake.
ugh calibration every time.. it can't auto detect endpoints?
and is reverse disableable? wouldn't have any problem running a neu, correct? |
Looks like a fair priced controller then! how are the brakes? not adjustable?
The brakes can't be adjusted. It is like a BK, but you only have forward/brake/reverse.
how is your controller getting along? did they get around the car-software problems?
The engineer said he will have everything sorted out in the next few days. I'm not saying much about my controller, because I really want to test it first. I will make a video of the Schulze 40.160 and my controller to see where it stands. I hope it does well against what many consider the best controller out in the market right now. |
| All times are GMT -4. The time now is 05:05 AM. |
