-   -   Utilizing my 3s 6000 packs? Truggy? (https://www.rc-monster.com/forum/showthread.php?t=8109)
rc10mike 10.12.2007 02:24 PM
Ive been running a MM 5700 combo in my Pede with Maxamps 3s 6000 packs, they are the older 90A Cont. ones.
Do you think a 3s pack would work well in a truggy? I know 4s or 5s would be better, but since I already invested in three 6000's, I would like to use em'.
I dont need the fastest set-up, the track is very small and technical. I was looking into running a 9XL with my MM, or would an 8XL be more suitable with the 3s?
Arct1k 10.12.2007 02:30 PM
I can 8400 3s packs in my revo with a 9xl - it was good but I switched to 4s and it was much better.
You could look 6s with a better ESC and slower motor!
gixxer 10.12.2007 02:44 PM
I dont think 3s on the 6000mah maxamps are going to work very well in a truggy. The 6000mah packs are not the best. I have a 5s 6000 for my truggy and my enerland 5s 4350 pack makes it a totally different truck.
since you have 3 of them I would look at a 6s setup. only problem is then you would need a better esc.
rc10mike 10.12.2007 04:20 PM
Whats the runtime difference between the 5s 6000 and 4350?
Where did you get the Enerland Packs?
gixxer 10.12.2007 09:44 PM
my enerland pack has a lot more punch then the maxamps 6000mah one. it also runs cooler. As for runtime I get 15minutes on the enerland and 19-20 with the maxamps. Your times will vary though depending on your motor, gearing and driving style. I got the pack from ebay. flightpower packs also use the same cells.
