-   Fastlane Machine (https://www.rc-monster.com/forum/forumdisplay.php?f=22)
-   -   gear ratio (https://www.rc-monster.com/forum/showthread.php?t=8113)
shawzie 10.12.2007 10:54 PM
gear ratio
Hi guys,I was wondering with the lightning diffs in the hybrid bulks would I keep the same gear ratio?or am I going to have to change anything?I am running the 3.3 but bought the hybrids so in the future I can go BB.I just don't want to lose any power and also not have to change a bunch of gears,I guess my question is will the lightning diffs fit right in and give me the same power as I have now.Thanks.
tashpop 10.13.2007 08:23 AM
they are a lower gear ratio. you'll need to increase you pinion size, and/or decrease you spur gear. there is a real nice speed/gearing calculator in the sticky section under brushless.
lincpimp 10.13.2007 11:52 AM
You can use the buggy ratio (43/13) gears which are close to the maxx gearing (37/13), than the truggy ratio (43/10). You should be able to compensate with a larger pinion or a smaller spur.
shawzie 10.15.2007 01:47 AM
Does anybody else know other diff options besides the lightning diffs?Thanks.
wallot 10.15.2007 03:36 AM
kyosho 7.5 diffs, but hardened lightning ones are one of the best
shawzie 10.15.2007 08:43 PM
would a ofna hyper 7 diff fit?Thanks for all the replies guys,I really appreciate it.
