Center Diff?
My E-Revo is nearly complete. Here are the specs Neu 1515 2.5D, Quark 125B, 5s Maxamps battery, Robinson Racing Wide Ratio FOC (steel Gears), JR 8711 steering servo, Specktrum DX2.0 radio, RCM hybrid diffs. I thinks thats all. So my question: Is a center diff a good Idea with this setup?
Thanks, Josh |
I would try it. If its setup right, it can only help. It would be beset utilized if you are using mechanical brakes.
the only weakness would be the plastic gear, but its wide and should be ok
| All times are GMT -4. The time now is 09:14 AM. |
