-   -   crt .5 plastic spur thoughts (https://www.rc-monster.com/forum/showthread.php?t=8230)
entjoles 10.21.2007 09:53 AM
i was looking at the robinson racing spur and thinking
http://www3.towerhobbies.com/cgi-bin...&I=LXSNC8&P=SM
could i mount this up and modify a plastic spur to bolt up to this by cutting out the center of it and bolting it together?
http://www3.towerhobbies.com/cgi-bin...&I=LXGFW9&P=SM
it looks possible, i would just need to have clearance on the sevo and run the pinion out a little bit
let me know your thoughts on this thanks
Serum 10.21.2007 11:44 AM
You don't necessarily need a plastic spur. You could use a hardened pinion.
jhautz 10.21.2007 12:50 PM
Serum is right. Save yourself the trouble and just run the stock steel spur with one of Mikes hardened pinions. They work great.
entjoles 10.21.2007 05:23 PM
thanks, i am running those pinions now, i was just trying to make it more quite
BrianG 10.21.2007 07:42 PM
One word: earplugs. :lol:
Seriously, if you are really concerned about it, you could use a Kyosho 46T spur, but will need other modifications. You could even use a CD from a 8th scale buggy if you are going to go that far. But, the footprint will be different, which will require new chassis holes and shorter driveshaft.
I did quite a bit of discussion about using different spurs in this thread (starts at post #117). There are a bunch of pics and measurements of the spurs and different ideas I had if that helps you at all...
entjoles 10.21.2007 09:26 PM
thanks for the link,
i will be reading for awhile:rofl:, i must have read this before and forgot about it, i never have original ideas:lol:
