Custom Kydex Battery Tray
1 Attachment(s)
Hey all,
I need a battery tray for a project I am working on. I have attached a diagram and hoping somebody here can point me in the right direction. I was thinking about using Kydex (the same material many tactical gun holsters are made of). Kydex is incredibly strong and rigid...but not too rigid. Any ideas on where to go or alternate materials? Graphite Elegance would have been an option but I can't seem to get a response from them and Kydex seems like a good alternate for this application. Appreciate any advice offered. |
Hi i made my battery tray's from kydex & they are great. I have all the kydex you want for free, just pay shipping. It'a approximently 3/32 thick i also have 1/8 inch thick your choice. |
Here are some pics of my trays . http://www.skellyo.com/hippie/ Yes a ban saw & table saw. Then i cut a 2/4 to the size i wanted the tray to be. then i clamped it in a vise & used a heat gun to form it. the trick is once you heated & formed it dont move it untill it totally cools, or it will change shape. |
rchippie, do you know where to get this kydex? I tried to look at mcmaster bust couldnt find any. What other sizes that you have? Im willing to buy it from you.
cool!! I'll PM you later with the size that I need. Thanks alot!!
No problem im thinking i could cut 10x10 or 12x12 squares. then you could make what you want. |
Hey, I'd like to get a couple 12 x 12's of this. Also, If you can get a spec on on it, we may be able to utilize this at work......
Sent you a pm.... |
Would this kydex be easier/better than lexan to make battery trays out of? I have tried a few times to make the trays out of lexan and it worked ok, but the lexan does not bend too easily, even with heat. Do you glue the sides where thay meet up?
Sent you a PM rchippe. :smile:
Yes i think there are alot eaiser to make with kydex veruses lexan . No i used right angle aluminum to make my end caps. Check my ERT pics that i posted in this thread, for ideas. http://www.skellyo.com/hippie/ YOU GUYS DO KNOW THAT MIKE CAN MACHINE CUSTOM BATTERY TRAY'S FOR YOU. |
| All times are GMT -4. The time now is 03:41 PM. |
