-   -   MM with a Novak 6.5HV 3s in CRT .5 (https://www.rc-monster.com/forum/showthread.php?t=8408)
Arct1k 11.02.2007 04:39 PM
Any thoughts - will i get cogging? Looking at
1) a used 6.5 HV for $50
2) a used Lehner 3100 XL for $90
Leave it with a Mamba 4600
Thanks,
A
entjoles 11.02.2007 05:53 PM
i just put a 4.5 in mine and will try to get a video tonight, its fast, little cogging on 3s and i will be checking temps
jnev 11.02.2007 06:17 PM
I think you should get the lehner. The performance is top notch. But if you don't get the lehner, PM me where you can get it for $90 please. :smile:
entjoles 11.02.2007 09:11 PM
video 3s hvmaxx 4.5 motor and mm
here it is , ill try to get a better one tommorow, very little cogging, temps were good batt. and esc got the warmest, motor cold
when i came in i after 10 min temps were 80 battery, 85 esc, 75 motor ( around 50*f outside)
i will try this on 2s to see if its driveable:neutral:
to extreme for me!!!:yipi::na:
http://www.youtube.com/watch?v=JdqHrUVXrdQ
oh and punch control was at 80%
suicideneil 11.02.2007 09:16 PM
What esc did you use, MM? It does perform extremely well in lighter vehicles, so in theory the 6.5 motor would be a bit tamer, but still really fast & torquey.
entjoles 11.02.2007 09:22 PM
it works , but must be in a light truck(?)
the 6.5 would be better, one of the wheel nuts kept coming loose, tires looked like doughnuts, but i have not tested on 2s which would be better if it works, the mm does not have the software to run but it seems good in this lighter truck
yes, mamba max
