Brushless Jato Project
I need to know what the best motor/esc combo would be if I going to run
2S2P 8000 Mah MaxAmp batteries. I'm using a single speed tranny. What would be a good gearing to start with? Looking for 50 to 60 mph. |
Check out BrianG's calculator, should help you out. But I can tell you you're are going to need a hot motor to get that speed on 2S.
| All times are GMT -4. The time now is 01:37 AM. |
