-   -   Tires (https://www.rc-monster.com/forum/showthread.php?t=8474)
Sower 11.06.2007 11:58 AM
Tires
Ok, I'm not sure if this has been addressed here or not . . . if it has, sorry. You can just post a link to the thread and I'll check it out. As the title says - this thread is about questions I have on truggy tires.
My first question is about offset. I see some people using adapters to run 0mm offset and I don't know why. Can anyone tell me the advantage there? Why would I or wouldn't I want to go that route?
My second question is about tire profile. I see many of the lower profile tires like on the new X2-CRT and the 8ight-T, but not every truggy is going that route. Like the XT8 for example. So my question is . . . is the lower profile better? And if so - why?
Thanks in advance to everyone.
tallyram 11.06.2007 04:08 PM
i know on the xt8 the steering rods rub the inside of the wheel, so i ordered a set of king headz 11mm offset hubs and a set of dace 6mm offset hubs for mugen mbx5(dace doesn't make them for xray, but mugen uses the same drive pin) to run 0 offset wheels. i like the grp cubics, which are premounted and low profile. they don't balloon as much and they have less sidewall flex.
Sower 11.06.2007 04:12 PM
I see. My extenders for my XT8 are KMW but I don't know what the extension measurement is. It came with two sets of 0mm offset wheels though. I'm trying to decide if I want to keep them or go to something else. I've never run 0mm offset so I don't know why I would or wouldn't.
Where did you get your grp cubics?
crazy4wdracer 11.06.2007 05:37 PM
Offset just depends on your driving style. 0 offset wheels will let you whip better in the turns. 1/2" offset or fulloffset wheels will make it a little harder to whip but it will make the truck feel more stable and less likely to roll over. Like I said, it just depends on your driving style.
Sower 11.06.2007 06:33 PM
Hmm, interesting - thanks for that. I'm not sure what my driving style is now that I think of it. I try to make my driving style fast. :lol:
Seriously though, I'm not sure what my style would be. I guess I like the idea of having that tight turning radius so maybe 0mm offset is for me. :neutral:
tallyram 11.06.2007 06:41 PM
what i was trying to do was to use 0 offset wheels and get back to the stock width of th xt8, thats what the adapters are for. you want to keep factory width, thats what all the r&d is for! i wouldn't go messing with the width of the truck. i'm sure xray spent tons of money on the research that brought to the width of the xt8.
Sower 11.06.2007 06:44 PM
Good point. So, what is the overall width including tires? Then I can measure mine and see how close it is.
tallyram 11.06.2007 07:12 PM
go to teamxray.com.
Sower 11.06.2007 07:17 PM
I should have thought of that. :tongue:
t-maxxracer32 11.06.2007 08:30 PM
wow. i could not imagine how weird/crazy your xt8 would look with some wheel extenders AND full offset. wouldnt that make it like 1-2 inches wider?
Sower 11.07.2007 11:14 AM
Sweet - that would be hilarious. I think what I'm going to do is go to the regular offset but use the larger diameter wheels and lower profile tires. Like on the 8-T.
tallyram 11.07.2007 04:20 PM
the only wheel with the correct offset is made by xray! if you switch, you'll need 0 offset with an adapter to get back to factory width.
Sower 11.07.2007 04:37 PM
Well, the factory width is a range - it's not exact. Are there any options to go with the larger diameter rims and lower profile tires? What is the factory offset of the tires anyway?
tallyram 11.07.2007 07:32 PM
i have read 11mm is built into the xray wheels. i was told to buy +6mm hubs and then i was told to buy +11mm hubs. the king headz +11mm hubs are what i'm running at the moment and the work well. they are also listed for the xray xt8 specifically!
Sower 11.08.2007 10:44 AM
And what about the rims? Won't one of those offsets work with the new Proline wheels? I'm talking about these:
http://www.pro-lineracing.com/proline.html
