Good BL System
So i had my heart set out on the HV 6.5 for a little bit now and was pretty sure i was gonna go wit it...until i heard people say it is not the best way to spend $300.
so, $300 is my MAX budget. im going to be running EP 4200 7 cells. I alwso want a system i can drop in there, mainly the motor, i can deal wit finding a mount for the ESC. Im very new to BL systems so i get real confused when people talk about neu and fiego?... i will be doing mostly bashing and i would like a top speed of 45+ I was hoping someone here would know waht set up i should go with with my budget. I heard yall were the best to talk to about this. Thanks |
mamba maxx esc and a fieago motor would be a much better choice probably a 9XL or 10XL motor with RCM heat sink.
BTW welcome to the forums |
I will second that, might want to gear for 40 instead of 45, it will help keep the heat down.
If only running 14 cells, the 9 or 10XL will be to slow. Go for a 7XL, maybe a 8XL if runtime is a concern.
sweet! quick questions i forgot to ask
do you guys agree that getting the Hv is a bad way to spend 300 on brushless? or not the most efficient? what is the difference between the 7xl and 8xl is it a turn number?speed? what speeds can i hit with the 7xl and 8xl any modding required to install the 7xl or 8xl? thanks!!! |
yes the 8xl and 7xl and mabey even the 9xl motors and castle esc are much better than the novak setup hands down. If i am not mistaken the number in front of the XL is the winds.
i think im going to go with the 7xl and mamba max esc.
but a question, how to i wire the batteries?i see there is only one set of battery connectors. does the system still require 14.4v? |
The 7XL might be a little too "hot" for the MM IMO. The 8XL is the lowest I would go. But I suppose if you watch the temps on the ESC and gear accordingly, you should be ok...
get a series connector. connect it to both batteries and it will connect right into the mm esc. |
sweet wont be too ahrd to make that.
Do i need the UBEC by castle to run 14cell? are my EP 4200 7cells a high quality battery good for this system? where in the world can iget IB batteries? |
Yes, get a UBEC for anything 3s or more!
TBH, I think you'd be happier with lipos if you can swing it. I don't think I've seen any NiMH cells that can provide the current AND voltage BL systems can pull... not without stressing them anyway. |
Just to play devils advocate for a minute I would say that the HV 6.5 system is a good reliable turnkey setup for a Maxx.
It may not go 45 mph but we're talking about an E-Maxx here right? It trips me out to see guys setting up a "Monster Truck" like a race car. If you want to go that fast you should put that Neu or Fieago system in a buggy. It would go faster and handle better. I have a HV 6.5 in my maxx but it's made for bashing and running over stuff. It has all the power that the terrain I like to run on can handle. If I put it on the street I can see where you might want a little more juice. But for off road, it has plenty of power. |
ok thanks for the info guys!!
another Q, would the MM and 8xl be so much powr that i need stronger diffs? i forgot to sayi dont want a system thatll rip my stock maxx in one run but dont worry, im going t odo a complete 3.3 conversion:rofl: |
| All times are GMT -4. The time now is 06:53 AM. |
