-   -   Aluminum hopups (https://www.rc-monster.com/forum/showthread.php?t=854)
captain harlock 07.10.2005 08:39 PM
Aluminum hopups
My B4 and T4 lacks the durability that is needed for extreme brushless power and I've thought that some of you might know how to make them evolve into a state of a bullet proof off road cars and also make them heavier with aluminum, steel,etc. Any help will be most appreciated.
squeeforever 07.10.2005 09:08 PM
why would you want them to be heavier?
captain harlock 07.10.2005 09:10 PM
Because I'm using motors that pull them around like papers.
squeeforever 07.10.2005 09:34 PM
ah. makes sense. what are you running? i have a xxx bk and am thinking about going brushless.
sleepy23 07.10.2005 10:50 PM
what exactly are you looking to make heavier? you can go with al suspension arms, al towers, al rear plates, al motor guard, al tranny case, al diff gear...defiantly go with lunsford ti tunbuckles and hinge pins....really depends on where are how you want to add weight, there are alot more al parts than what i mentioned.
captain harlock 07.10.2005 11:50 PM
Yes. That is exactly what I'm looking for. Full aluminum parts for my sweet t4 truck. If you know some place that sells such things please tell me as soon as you can Sleepy.
Squeeforever: I'm using the Lehner 1920/8 turn motor with warrior 9920 and 11 cells pack for my T4 and the Lehner 1930/5 turn with Mamba Maxx( as soon as it becomes available) and 12 cells pack for my B4. I think such hopups is needed for such powerful setups. Right?
captain harlock 07.11.2005 09:08 AM
Hey..I'm still waiting you know.:M:
MetalMan 07.11.2005 09:31 AM
Here are some aluminum parts for your T4:
http://www.hobbyetc.com/cgi-bin/cata...id=144&cat=all
Re~Mix 07.11.2005 10:06 AM
Beware that aluminum in all places is not the best. I suggest you start with titanium turnbuckles/hingepins and rpm rod ends. Then get aluminum pivot blocks, and beef up your tranny.
captain harlock 07.11.2005 10:07 AM
Impressive. Need either a woven carbon fiber or aluminum chassis for the car as well.
captain harlock 07.11.2005 10:11 AM
Yeah, I think I should do so first.
squeeforever 07.11.2005 12:28 PM
you have a t4 and a b4 right? dont they use the same chassis?
captain harlock 07.11.2005 12:52 PM
The T4's is longer and the B4's shorter.
sleepy23 07.11.2005 09:17 PM
i am in the process of making some cf chassis'. i have a couple of different versions in the works. once done, they will be untouchable
captain harlock 07.12.2005 12:05 AM
You mean one of them is suitable for the T4?
